4.5L Stroker From Ebay
Posted: March 30th, 2020, 12:23 pm
Hey all, I've made a post earlier about setting up a stroker but I finally pulled the trigger on a crate motor from a shop in WA for 2100 bucks, its been balanced and reassembled etc so I figured it was too good of a deal to not take. It's going into a 1989 XJ. Just wanted some advice about if I should pick up a high volume water, thoughts on leaving the Renix intake and exhaust and just getting a bored out custom TB and what kind of injectors to start with. I also picked up a wideband kit for 120 so that'll help me with monitoring how its burning. Anything that comes to mind with this parts list/build please let me know!
Up for sale is a professionally rebuilt JEEP 4.0L Engine that has been Stroked to 4.5L.
Engine ONLY Fits Jeep applications from 1987-1990 that came with the 4.0L with Vin codes "L and M".
Will not replace 4.2L (258) Applications................4.0L ONLY for these years.
Engine is @ .030 Oversize and the Crankshaft is STD/STD (New SCAT Crankshaft)
Engine features new Silvolite Hypereutectic Pistons and Hastings Moly Rings, Clevite Rod and Main bearings, Durabond Cam bearings, Melling Timing set, and Oil pump, Oil pump screen, MAHLE Engine gasket set, New SBI Valves and Springs, New SCAT Crank (3.895 stroke, Crown 5.875 length rods, and a special ground camshaft with a "248" Grind.(200-200@ .050 with 0.412 lift with a 112 lobe separation). The rotating assembly has been balanced. Engine compression is 9.2:1
We highly recommend replacing the stock fuel injectors with 19LB-22LB an hour Ford Mustang fuel injectors.
We built this engine for one our workers friends. He supplied the core and we supplied all of the New parts.
He told to sell the engine because his financial situation had changed and could not afford to pay for the engine.
We are a Machine shop that has been in business for almost 40 years. We were the exclusive engine builder for "WEST COAST ENGINES" from the inception until 2020 when we decided to shut the doors.
Engine is SOLD AS IS! No core is required and no warranty is expressed or implied!!
