ECM gone bad
rurys
Vehicle Make: tj
Vehicle Model: sport
ECM gone bad
Post by rurys »
Hi guys , the name is Rury and I Owen a 2002 Jeep Tj 4.0stoked to 4.6 I am having electrical issues I am located in south west Cali any one know of any company that works on ecm rebuilding.thanks [email protected]
SkylinesSuck
Re: ECM gone bad
Post by SkylinesSuck »
How sure are you it's the ecu? I thought mine was bad for a while but it turned out to be the harness.
rurys
Vehicle Make: tj
Re: ECM gone bad
Post by rurys »
SkylinesSuck wrote: May 29th, 2019, 10:15 am How sure are you it's the ecu? I thought mine was bad for a while but it turned out to be the harness.
It turned out it was the eprom on the ecu had it fixed and reflashed put it back on and seemed like it wanted to turn on however it wouldn't seance the problem started with a broken cam sensor I remove the dsi shaft and the gears turned out strip replaced it with a new one and made sure the number one piston was at tdc and double check my timing marks and gave it a go and jeep turned on next step is a stroker cam any suggestions???
rurys
Vehicle Make: tj
Re: ECM gone bad
Post by rurys »
rurys
Vehicle Make: tj
Re: ECM gone bad
Post by rurys »
now we good
Users browsing this forum: No registered users and 18 guests
