Cam selection for max torque 2250 RPM
Posted: March 24th, 2019, 7:20 pm
Getting ready to build my 1st stroker here. this will be a rebuild of my late grandfathers 2002 Jeep Grand Cherokee WJ, not trying to build for HP or speed, looking for max torque off the line and peak at cruising RPMs of around 2250 RPM at 80MPH approx. planning on doing a lot of towing cross country. 87 octane or maybe even E85 / 87 octane are options being considered , already have a 4 CW crankshaft from a 80s 4.2 reconditioned looks to be in real good shape. hopefully can I do an offset grind to 4.06. assuming I can find the correct length rods, not wanting to bore it at all unless I have too. trying to do the "BULLETPROOF" build AKA severe/heavy duty parts.
heres what im looking at so far any info in what direction to go with this build is appreicated , heres what I came up with so far
Jeep Strokers
Jeep - AMC 4.0L and 4.2L Stroker Enthusiasts
Static/Dynamic Compression Ratio Calculator
calculator/
Your Data:
Cylinders:
6
Cylinders
Bore:
3.875
inches
Stroke:
4.06
inches
Combustion Chamber:
62
cc
Deck Clearance:
.00
inches
Gasket Thickness:
0.043
inches
Gasket Bore:
4
inches
Dome/Dish/Valve Relief:
25
cc
Piston Ring Height:
inches
Piston to Bore Clearance:
inches
Altitude:
900
feet
Connecting Rod Length:
6.15
inches
Cam Intake Duration:
248
degrees
Cam Lobe Separation Angle:
108
degrees
Advance or Retard:
0
degrees
Your Cam Selection:
Manufacturer:
Mopar
Model Number:
P4529229AC
Your Calculated Results:
Cubic Inches:
287.28
Liters:
4.71
Static Compression Ratio:
9.19
:1
Dynamic Compression Ratio:
8.04
:1
Dynamic Compression Ratio (@ Altitude):
7.86
:1
Quench:
0.043
Intake Valve Closing Angle:
52
Thanks for your time Rob Jenkins
Jeep Strokers
calculator/
Your Data:
Cylinders:
6
Cylinders
Bore:
3.875
inches
Stroke:
4.06
inches
Combustion Chamber:
62
cc
Deck Clearance:
.00
inches
Gasket Thickness:
0.043
inches
Gasket Bore:
4
inches
25
cc
Piston Ring Height:
inches
inches
Altitude:
900
feet
6.15
inches
248
degrees
108
degrees
Advance or Retard:
0
degrees
Your Cam Selection:
Manufacturer:
Mopar
Model Number:
P4529229AC
Cubic Inches:
287.28
Liters:
4.71
9.19
:1
8.04
:1
7.86
:1
Quench:
0.043
52
