4.2 mini-stroker spark plug temperature?
Posted: March 12th, 2019, 12:45 pm
This should be my last damn question before getting this thing back in the vehicle (still plan on dropping the transmission/T-case in order to rebuild the latter, clean everything, and get the wiring harnesses installed neatly)...
My 4.2 mini-stroker is running a ~10.3:1 static compression ratio with a somewhat mild cam (slightly-modified Comp 68-201-4, if I'm not mistaken). Should I plan on running stock plugs, or something cooler? I'm guessing the former seeing as I can't find any discussion of the topic outside the scope of "normal" strokers (4.6+).
Thanks in advance.
Thanks in advance.
