				Dome pistons
				Posted: July 26th, 2018, 12:08 pm
				by aguiar_racer
				Anyone ever use dome pistons on strokers
Mines at 4.000” bore trying to find some ford or chevy domes pistons tbat would work zero deck on block & cyl head
				Re: Dome pistons
				Posted: July 26th, 2018, 9:24 pm
				by Russ Pottenger
				Why would you want to run a dome piston?
You'll be at 14.0:1 with a flat top piston.
 Way more desirable to run a flat top over any dome piston.
 My advice would to run a 3.970 bore piston allowing you to run a commonly available off-the-shelf head gasket.
 This is a common flat top piston that I keep in stock.
 That said, i'll build you anything you want  : )
 Shoot me a call or email if you'd like more information on my Pistons.
Russ
				Re: Dome pistons
				Posted: July 13th, 2019, 7:52 pm
				by gsune
				Hi, what do you think about using a ford explorer 4.0 pistons? 6.125" rods they are lighters 100 grams. must work the rod pin diameter
				Re: Dome pistons
				Posted: July 13th, 2019, 10:49 pm
				by Russ Pottenger
				gsune wrote: ↑July 13th, 2019, 7:52 pm
 Why not run a piston for a Jeep?
Just about any specification you choose.
$515.00
Bishop-Buehl Racing Engines
Work (626) 967-1000
Cell   (626) 673-2203
[email protected]
				Re: Dome pistons
				Posted: August 22nd, 2019, 8:17 pm
				by gsune
				In my country (venezuela) i  can buy a set of 6 new pistons  for 100 us$
