New 4.6L build
Posted: February 28th, 2018, 6:41 am
Hey all, never built an engine before but with the rest of my jeep more or less done mechanically, I decided the engine needed an upgrade. I've been lurking the forums for a while now and I think I have a pretty good idea as far as my recipe, I'd love to get some feedback
Renix intake/fuel system (runs rich, thinking 22lb injectors instead of 24)
60mm throttle body
'97 block bored .030(probably stock deck height, thoughts?)
0630 head (minor port work to be done, basic lapping to match valves)
Ic944-030 pistons (Hastings moly rings)
Scat 6.125 forged rods
Scat 9-4.2l-3895 crank
Comp cams 231 or 232 (I would like to use stock valve springs, mp are so expensive! will either of these cams work?)
Crower cam saver lifters
JP 5629 timing set
High flow oil pump
Clevite bearings all around
Sealed power gasket set
Pretty sure this gets me to a 9.07:1 scr and 7.74 dcr. I would like to run mid grade if possible but not opposed to running premium. I know the quench height is a little high at .0725, I suppose I could always get the deck height down or use a .043 head gasket but I'm definitely trying to save money at the machine shop. I've read that a tight quench is super important for power and I've also read the opposite so I'm not really sure what to think.
60mm throttle body
JP 5629 timing set
High flow oil pump
