Hello guys, new here trying to figure out way to get over this wall I’ve ran into. I have an 06 Wrangler and swapped out the 42rle auto trans for a 5spd ax-15. I know I can buy an adapter bellhousing, however I am seeking to attempt modifying the bellhousing myself first.
I know that the distance between the flywheel and sensor has to be exact. However I do not know if the clocking matters eg. (2O’clock vs 3O’Clock)
Thank anyone who can help in advance,
Mike
05-06 Does CPS clocking matter???
- Vehicle Year: 2006
Re: 05-06 Does CPS clocking matter???
Clocking affects the crank signal to the ECM. IE crankshaft degrees of rotation to signal pulse.
Buy the bellhousing and be done with it.
Users browsing this forum: No registered users and 31 guests
