Fuel Pump Question
Posted: August 20th, 2017, 7:15 am
Does anyone have a wiring diagram that shows the whole fuel pump circuit for a 94 yj? My pump isn't priming with the key in the on position, the ECU comes on with the key in the on position, all relays and fuses are new. Given that this problem only seems to happen intermittently I'm thinking that it's a bad ECU, but I want to try to run down any loose connections before replacing the computer.
