Will these Comp cam work without a Comp or modified head?
kaspbrochill
Stroker Displacement: Soon to be 4.7 & 6.7
Vehicle Year: 9698
Vehicle Make: Jeep's
Vehicle Model: 4.0/5.9ZJs
Post by kaspbrochill »
Hey guy's i'm in the process of rebuilding/ minor stroker motor on my 96' 4.0 Grand Cherokee ZJ and really need to input/ advice on my build. I was originally going to build a 4.7 stroker but i've decided against because I am custom swapping in an AX-15 5spd trans. when I drop the motor in rebuilt and I know for sure that the trans. WILL NOT be able to handle the HP of a 4.7...i'd be lucky to keep it intact til 3rd gear before blowing through it so I decided to do:
-complete engine rebuild w/ hi flow oil pump
-bore it over .30
-Comp cam https://www.summitracing.com/parts/cca- ... /make/jeep
-Comp valvetrain
-Comp timing chain/gears
-Port/match my head (pulled a 93' XJ head), intake manifold and Gibson header's
-Performance Distributor's Firepower ignition (screamin' demon coil pack allows you to gap spark plugs to .065)
-Roller Rocker's..can't decide whether to get Harland Sharp 1.6 adjustable rockers or Yella Terra's ( I can get the Yella Terra's cheap)
-SCT tune
-Custom full 2.5" exhaust back (Magna. Hi flow cat, Flowmaster 44 muffler)
I already have the Comp Cam kit( https://www.summitracing.com/parts/cca- ... /make/jeep ) however, i'm not sure if the cam is too lopey for a non- comp. head or modified head...anyone have any advice or two cents?
Also if anyone has any suggestion's or critique on the build, I am all ears for suggestions!
Thanks guys!
kaspbrochill
Vehicle Year: 9698
Re: Will these Comp cam work without a Comp or modified head?
Also, I need help on what intake/exhaust valve's I should run!!! I would like to port and run larger valve's; any two cents would be appreciated!!
kaspbrochill
Vehicle Year: 9698
EDIT: Sorry I posted in the wrong section by accident; I reposted in stroker/ Performance tech if you guys would please respond to that post, thanks!
Users browsing this forum: No registered users and 18 guests
