Does anyone know if a 258 Flowkool water pump will fit on a 4.0 block. Read somewhere about someone dirlling a extrs bolt hole.
Want to stay with all org. mounts and V belts.
Water Pump
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: Water Pump
you said vbelt so im guessing youre on top of the fact that 4.2 water pumps go the other way from 4.0s. not sure about the mounting though
1980 AMC Spirit Restomod in Progress
- Stroker Displacement: 3.9L
- Vehicle Make: 1999
- Vehicle Model: sx4
Water Pump
In the tower is a adjustable pressure valva, just a little screw thing, turn it up and the pump works on a higher pressure, turn it up too much and the pump will cut in and out for no reason and burn out.
Users browsing this forum: No registered users and 19 guests
