				Non electric coolant temp issue
				Posted: January 28th, 2016, 8:39 am
				by amceaglesx4
				Not sure where to put a coolant sensor on a 4.0 block. Any ideas ? The one in the back of the 7120 is too small and the thermostat housing ain't happening due to a bracket in the way from my 4.2.
				Re: Non electric coolant temp issue
				Posted: January 29th, 2016, 7:22 am
				by beater_renix
				It sounds like you are using a 4.2 block on a 4.0 head?   I can't tell enough about your setup to help you.  There are two sensors on most jeeps, one for the ECM, and one for the instrument cluster.  On a Renix Jeep the sensor the ECM uses is located below the exhaust on the block.  There are two threaded bungs down there, one for this sensor, the other is just plugged.  You should be able to extend the wiring and relocate it there.
Since your running a 7120 head, it should have the sensor bung at the back of the head for the gauge, so I'll assume that you mean the one for the ECM.
In the second picture they are the two brass fittings down by the motor mount bracket:
http://www.jeepstrokers.com/forum/viewt ... =75#p43067
				Posted: January 30th, 2016, 8:33 am
				by amceaglesx4
				Its on the stroker. Its a 4.0 and yea there is a plug on the head but its really small. I did find an electric one that looks like it would fit.
