Electric Water Pump for engine off cooling?
Posted: January 10th, 2016, 12:23 am
So this is more of a backburner idea I thought up a few days ago. I'm sure my old engine may have done this too but with the stroker once I turn the engine off and then flip the key back to run, I notice the temperature rises 10*F - 20*F which is a little worrying for it being cold out. I don't know if that's something to worried about, but I feel like if you were already overheating and shut off the engine it would rise to unsafe levels.
My first mod is going to be installing a 2 speed temp switch and volvo fan, then rigging them up to run even when the key is off to cool the rad and engine bay. They would shut off when the temp switch cooled sufficiently, but that's just the rad temp, not the block temp. So my thought was to add a smaller secondary water pump that can move the coolant through the block and cool the engine down without the running engine adding heat back into it. I only looked quickly but noticed some small inline electric water pumps on ebay so it may be possible.
Is this something I should pursue further, or am I starting to German Engineer this too much? Thoughts and Suggestions welcome.
