Will these fit?
Posted: November 21st, 2008, 1:17 pm
by RAPTORFAN85
Re: Will these fit?
Posted: November 21st, 2008, 3:29 pm
by gradon
The injectors pictured will fit pre 99 jeeps, not your 2001, due to the newer style harness you have. You'll have to find ev6 style connector injectors iirc.
Re: Will these fit?
Posted: November 21st, 2008, 3:41 pm
Not only that they will be flowing too much fuel for a 4.0l or a 4.7L
Re: Will these fit?
Posted: November 21st, 2008, 8:55 pm
by seanyb505
Those are actually the exact injectors I have in my 97 stroker. Runs fine, although I have never tuned it. I dont think they are using too much fuel as I still get 16-17 mpg, same as before the stroker.
Re: Will these fit?
Posted: November 22nd, 2008, 4:53 am
seanyb505 wrote:Those are actually the exact injectors I have in my 97 stroker. Runs fine, although I have never tuned it. I dont think they are using too much fuel as I still get 16-17 mpg, same as before the stroker.
You did see that at 50 psi (one PSI more than what your system is pushing) they are putting out 27lb? That is a little much for a 4.7L. In your case at 49psi theyw ould putting out 26.6lb. I had a set of ford Cobra injectors that flowed similar to those. With out the Apexi interfering it was putting out greater than 10:1 at WOT, i.e. rich. And my wideband only goes as high as 10:1, so it may have been richer. I am swapping them out for a lower flowing injector.
Re: Will these fit?
Posted: November 22nd, 2008, 6:37 am
by RAPTORFAN85
If you use this equation and expect 250HP:
Injector flow rate (lb/hr) = [Expected HP x 0.5 (BSFC)] / [no. of cylinders x 0.8 (injector duty cycle)]
( 250 x 0.5=125) / (6 x .8=4.8) = 26.04
Actual injector flow rate = Rated injector flow rate at 50psi x square root of (FP/50PSI)
27 x .98 = 26.46
Thats pretty close, and should work fine right?
Re: Will these fit?
Posted: November 22nd, 2008, 4:21 pm
Those equations don't really work. I've tried several of them and they all say like 26lbs. However, I have ran rich with 26lbs and for a stroker it seems every one is using 24lbs.
