Custom cam and degreeing question?
Posted: February 11th, 2015, 4:24 pm
by nicpaige
Okay so I went with a jones custom cam for my stroker build partly because I could get a core to utilize the cam retainer plate for my 1999 block. Unless I am mistaken I have read it is not possible to run a double roller chain and gear set with this retainer plate setup. Is that correct? If this is correct and a single roller chain is necessary, I am assuming the only way to change cam timing is with offset bushings? Thanks for any replies.
Re: Custom cam and degreeing question?
Posted: February 12th, 2015, 11:26 am
by jeepxj3
Great cam choice! Yes, Yes.
What specs cam did you get?
Posted: February 12th, 2015, 3:13 pm
by nicpaige
I guess an offset crank key would work as well.
Posted: February 12th, 2015, 4:10 pm
The timing set for that cam will not accept a cam gear bushing. However, an offset crank key would work just fine. The timing set is also not a single roller, but a morse style chain.
Posted: February 12th, 2015, 6:04 pm
by nicpaige
Thanks for the replies gents.
