Page 1 of 4
WJ Stroker build recipe.
Posted: January 11th, 2015, 1:51 am
by bellator50
Newbie here and I apologize in advance if I'm beating a dead horse :deadhorse: I searched but did not find a definite answer and hope someone here can straighten me out.
I have acquired an 01 Jeep WJ. The #3 piston was at the bottom of the oil pan so a build is in place. I have a complete AMC 4.2 and would like to build a stroker. I'd like to build a mild one but essentially need a recipe. The Jeep will be more for a daily driver. Can someone point me out to a poor man stroker build.
Re: WJ Stroker build recipe.
Posted: January 11th, 2015, 5:41 am
by Cheromaniac
Here ya go:
4.6L modified "poor man's" stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
Keith Black UEM-IC944-020 forged pistons
9.25:1 CR
Stock 4.0 camshaft
Ported 0331 cylinder head
0.070" quench height
Accel 24lb/hr injectors for '96-'04 engines
245hp @ 4800rpm, 315lbft @ 3000rpm ('96-'04 camshaft)
You'll need to:
Rebore/hone the cylinders +0.020"
Reuse your 4.2 crank (have journals checked by machine shop, regrind undersize if necessary)
Have the small ends of your 4.0L rods clearanced for the IC944 pistons
Source a reinforced 0331 head from Clearwater Cylinder Heads (the OEM '01 head is crack prone)
Buy an IC944 piston/ring set, new OEM oil pump, new OEM timing set, freeze plugs, upper/lower gasket sets, set of new lifters, harmonic balancer, water pump, thermostat, Accel injectors plus EV6 to EV1 adapter plugs
Posted: January 11th, 2015, 10:10 am
by bellator50
THANKS!. I'm assuming the quench height will turn out what it is with the parts used or do I need to do something else to achieve it. Also ... my block looks to damaged to bore out. What years and models fit .
Posted: January 11th, 2015, 12:38 pm
by jsawduste
That's a hell of a lot more quench then I would run with the fuel we have in this Country.
Posted: January 11th, 2015, 7:28 pm
by FlyinRyan
jsawduste wrote:That's a hell of a lot more quench then I would run with the fuel we have in this Country.
X2, IMO that is unacceptable.
Posted: January 11th, 2015, 9:26 pm
by bellator50
OK, so if it's to much quench,what is acceptable and how do I reduce it. Deck it?
Posted: January 12th, 2015, 1:48 am
by Cheromaniac
The 0.070" quench of the modified poor man's stroker is less than the 0.073" quench of the stock 4.0 but I agree that it would be better to reduce it to more like 0.040"-0.050".
Each 0.010" decked from the block will reduce the quench by the same amount, reduce the combustion volume by 2cc, and raise the CR by 0.2:1. If you want to keep the CR the same as it would have been if the block was undecked, you'd need to add 2cc to the combustion chamber volume for every 0.010" decked from the block.
Posted: January 13th, 2015, 6:10 am
by bellator50
This sounds like more of a headache than anticipated. :doh:
Posted: January 13th, 2015, 6:18 am
by jeepxj3
Buy Bulltear or RaceTec pistons and the Headache is cured.
Posted: January 13th, 2015, 8:31 am
by Cheromaniac
bellator50 wrote:This sounds like more of a headache than anticipated. :doh:
Here ya go. Less headache:
4.6L Modified "poor man's" stroker
9.25:1 CR
Stock '96-'04 4.0L camshaft
0.043" quench height
Posted: January 13th, 2015, 10:03 pm
by bellator50
Ok back in. Haha what year of HO head would work and do you have a suggestion of where to get pistons.
Posted: January 14th, 2015, 1:15 am
by Cheromaniac
bellator50 wrote:Ok back in. Haha what year of HO head would work and do you have a suggestion of where to get pistons.
You can get a set of Bulltear pistons from http://www.bulltear.com/catalog/product ... cts_id=242
As far as heads go I think you have two options; either an '02-'06 OEM head or a reinforced #0331 casting from Clearwater Cylinder Head at http://www.cylinder-heads.com/automotiv ... der-heads/
Posted: January 14th, 2015, 4:45 am
x2. It would be easier to stick with the 0331 head. But make sure its not an early non- 'TUPY' head.
Posted: January 16th, 2015, 12:39 pm
by bellator50
I'm a bit stumped. I used the stroker compression ratio calculator with info provided on this post but numbers are not adding up. Can someone point out my error. The calc does not show option for a 0.02 bore over so I manually entered it.
Posted: January 16th, 2015, 1:12 pm
by Cheromaniac
Make the chamber volume 57cc and the altitude 0 feet.
