2004 chevy injector work for stroker build?
Posted: December 14th, 2014, 5:01 pm
by nicpaige
A friend of mine had a set of OEM injectors off of a 2004 5.3 litre Suburban non-flex fuel engine. I believe these are rated at 24lbs/hr and that seems to be the go to size for a 4.6 stroker build. I am having a hard time finding out specifics on this injector and whether it will work with my 2000 XJ stroker build I am just beginning. Can anyone shed any light on this? Thanks
Re: 2004 chevy injector work for stroker build?
Posted: December 14th, 2014, 8:44 pm
Do you have any part numbers off the injectors? How long have they been sitting and how have they been stored?
Posted: December 21st, 2014, 2:26 pm
by crazygogo
what are the flow rate and ohms and etc? and go from there..
Posted: December 21st, 2014, 6:00 pm
by nicpaige
Well it looks as if this is a no go. I finally found a description and they look like they are flex fuel 36# injectors. They all have 14.7 resistence readings but a little big for my build. I will probably end up with some 24# FMS injectors.
