Page 1 of 2
4.6 stroker stalling
Posted: August 24th, 2014, 7:11 am
by turnbilljr
hey guys , having a problem with my stroker stalling . it doesn't do it all the time . sometime it stall at idle but will start back up. sometimes it will try to stall driving down the road at 60 mph. i have changed the crank senor and clean the air control on the throttle body. any ideas?
Re: 4.6 stroker stalling
Posted: August 24th, 2014, 11:03 am
Does it stall when you are off the pedal? Or when you are on the pedal at a constant point?
Posted: August 24th, 2014, 12:21 pm
by turnbilljr
well at idle your foot is off the petal. it will stall , but starts back up. driving down the road its a even speed . not increasing speed but not decreasing speed. even speed. it try to stall ,but its like it stalls but picks back up .
Posted: August 24th, 2014, 1:10 pm
If the throttle is open and it stalls its not the IAC. Spark or fuel. How old is your coil and have you checked fuel pressure when this happens?
Is it a sputter and die or a quick cut off.
Posted: August 24th, 2014, 2:22 pm
by turnbilljr
i have a new Screamin' Demon Coil and DUI 4.0 LiveWires and Firepower Cap and Rotor. buy them when i build the stroker 4 months ago. as the fuel pressures goes am running 44 psi. i have the Hesco adjustable fuel pressure regulator. i haven't checked it running down the road. guess i need to hook up a fuel pressure gauge. i have change out the fuel pump a year ago but it was the cheap one at advance auto parts. thanks!!
Posted: August 29th, 2014, 6:42 pm
by turnbilljr
well i checked the fuel pressures as i was driving down the road it runs about 44 psi . when the jeep stalls it stay around 40 to 44 psi. i did notice went it stalls out it wont start back . you have to turn the key off and back on then it will start right back up. seem like it all started went i put a alternator on the jeep. i had the OEM one on there but it was a 90 amp i was needing a high amp one . so i went to the junk yard on buy a 160 amp off of a 1997 grand Cherokee limited. i had it check before i put it on. they said it was good . so i put it on and it seam it work good 14.03 volts. do you think that could be causing the problem i am having????
Posted: August 30th, 2014, 5:28 am
I don't think the alt is the issue. Typically your voltage will drop very low first from a bad alt before cut off. I wouldn't completely eliminate it though. I would throw the stock one back on and see if it happens.
Posted: August 30th, 2014, 6:28 am
by turnbilljr
thanks for the help !!! i will put the old one back on today and get it a try . i am guessing its a electrical problem?????
Posted: August 30th, 2014, 8:04 am
by Cheromaniac
turnbilljr wrote:i have a new Screamin' Demon Coil and DUI 4.0 LiveWires and Firepower Cap and Rotor. buy them when i build the stroker 4 months ago.
If you still have your old stock coil and it was good before you removed it, I suggest you reinstall it and see if the problem goes away. It's just possible that your nearly new Screamin' Demon Coil is no longer screaming, and I wouldn't rule out the possibility of your new crank sensor being a dud either. Try the coil first.
Posted: August 31st, 2014, 11:14 pm
by turnbilljr
Cheromaniac wrote:turnbilljr wrote:i have a new Screamin' Demon Coil and DUI 4.0 LiveWires and Firepower Cap and Rotor. buy them when i build the stroker 4 months ago.
you think it could be bad . i paid 174. for coil ,wires , cap , roto button. i hope it would last longer than 2000 miles. what kind of coil do you use? The coil you get at advance auto and auto zone are junk . they only last about a year. i have no luck with those.
Posted: September 1st, 2014, 4:06 am
by Cheromaniac
turnbilljr wrote:what kind of coil do you use?
I still have the 22-year-old stock original.
Posted: September 4th, 2014, 6:24 pm
by turnbilljr
Hey Guys , well i change the alternator Saturday, put the original one back on. i haven't had any problems with it stalling . it runs really good .
just wonder why it wont work? i guess it something breaking down in it. thanks for all your help !!!
Posted: September 4th, 2014, 7:34 pm
by jbxx
That's weird, I wouldn't think that the alternator would cause the symptoms that you were having.
Posted: September 4th, 2014, 7:42 pm
by turnbilljr
yep, me either. it sound crazy, but its run great. no stalling.
Posted: September 11th, 2014, 8:04 pm
by turnbilljr
just a update on my stroker . all most 2 weeks now and it hasn't stall one time . running great !!
thanks !!!
