Standard rocker arms and pushrod lengths
Posted: August 6th, 2014, 6:16 pm
by Joshy
G'day fellas,
Just wondering how much lift the standard rockers arms can cope with? I'm looking at the Lunati 63500 or Comp 68-231-4 and both have around .485" at the most. Looking to run around 270 lbs of pressure at that lift. Do I need rollers or at least Hesco's heavy duty stamped rockers?
Also, looking to run 4.0 rods and IC944's and getting the block deck machined 27 thou so the pistons are flush and running the VR MLS gasket (41 thou). Anyone had similar setup that can recommend pushrods (or at least lengths)?
Cheers,
Josh
Re: Standard rocker arms and pushrod lengths
Posted: August 6th, 2014, 7:02 pm
Stock rocker arms will be fine unless you want the precision, easy of adjust and cost of rollers.
The MLS compresses to .043"- .044".
With a cam change, deck height change, possible head mill, valve job, lifter change, etc. its best to measure correctly for the push rods.
