				cam button and spring
				Posted: July 7th, 2014, 5:46 pm
				by sly-jeeper
				Trying to find a new cam button and spring is like
  ........does anyone know where to find one? Or even a good low milage one?
				Re: cam button and spring
				Posted: July 7th, 2014, 7:48 pm
				IIRC Hesco has them
				Posted: July 8th, 2014, 1:36 am
				by sly-jeeper
				I checked the website and couldn't find one, do I need to call or am I blind?
				Posted: July 9th, 2014, 7:19 pm
				by IH 392
				I got mine from the Jeep dealer, that was last fall?
				Posted: July 10th, 2014, 6:14 am
				by sly-jeeper
				I tried an online stealership
,.........do you have any other ideas I believe silver said something about just a machined pin to set the cam runout manually
				Posted: July 10th, 2014, 6:22 am
				by sly-jeeper
				My stroker is almost complete long block is assembled just missing the pin and spring, and the machine shop is finishing up the valve job =) by machine shop I mean a friend who builds race motors for a hobby. I ended up with a scat crank, resized rods, Mopar 229 cam, decked near zero, ic944 .030, stock felpro gasket, ported head with 60ish cc chambers .....9.6:1 @ 8.38 dynamic  if I remembers
				Posted: July 10th, 2014, 11:01 am
				Yes, just replace the pin and spring with a solid pin. Set end play manually by cutting the pin until you get the desired end play.
				Posted: July 10th, 2014, 4:17 pm
				by sly-jeeper
				Steel pin? Or should I use something softer?
				Posted: July 10th, 2014, 4:56 pm
				Steel. You don't want soft against soft. Soft against soft = gauling.
				Posted: July 10th, 2014, 5:02 pm
				by sly-jeeper
