cam button and spring
- Vehicle Year: 1994
Trying to find a new cam button and spring is like ........does anyone know where to find one? Or even a good low milage one?
Re: cam button and spring
IIRC Hesco has them
I checked the website and couldn't find one, do I need to call or am I blind?
- IH 392
I got mine from the Jeep dealer, that was last fall?
I tried an online stealership ,.........do you have any other ideas I believe silver said something about just a machined pin to set the cam runout manually
My stroker is almost complete long block is assembled just missing the pin and spring, and the machine shop is finishing up the valve job =) by machine shop I mean a friend who builds race motors for a hobby. I ended up with a scat crank, resized rods, Mopar 229 cam, decked near zero, ic944 .030, stock felpro gasket, ported head with 60ish cc chambers .....9.6:1 @ 8.38 dynamic if I remembers
Yes, just replace the pin and spring with a solid pin. Set end play manually by cutting the pin until you get the desired end play.
Steel pin? Or should I use something softer?
Steel. You don't want soft against soft. Soft against soft = gauling.
