4Liter Drinking Coolant
Posted: March 9th, 2014, 8:34 pm
I purchased a 2000 XJ not quite two years ago and the previous owner claimed to have stroked it 60 over with a new crank. By the numbers I calculate it at 4.7 after his mods. Although after owning the vehicle for a few months I began to question his mechanical prowess and am now doubting whether it was truly stroked at all. He claimed that he had repalced the heads and for the more reliable "less prone to warping" heads when they did the motor work, but of course I am questioning that now too. Engine also seems to be suffering from extremely low oil pressure at hot idle, off the bottom end of the factory gages and between 4-10 psi on a mechanical gauge. But the motor runs quiet, no clanky, grinding noises yet and I hope to keep it that way.
Question 1 - Is there an easy way to tell the good head from the bad head without tearing everything off the engine?
Question 2 - She seems to have an appetite for coolant. I never hear or see it steaming out the coolant bottle so I don't think its blowing combustion gases into the water jacket. It also has good clean oil, no foam or brown nasty stuff, like I would have thought. So I suspect coolant is burning up and steaming out the exhaust. Will a simple head gasket fix the issue or am I getting into a much bigger project?
Question 3 - Once I pull the head, confirming the stroker should be easy? Measuring between BDC-TDC will should confirm the stroke and measuring the diameter and a little bit of math should tell me what I bought.
Question 4 - If I pull the head, and it's warped, or the bad head, where can I get a new one that won't break, crack or leak in the future.
Question 5 - I live north of detroit so If I need to have machining rebuiling or fixing the motor, are there any fellow michiganders that can recommend a good machine and Dyno shop in the area.
