Big Cam Build - Excessive IATs?
Posted: January 10th, 2014, 10:13 pm
Hey guys, a friend and I are putting together a decent 4.0L build and have run into issues with upgrading the cam. What we have done so far:
1989 Renix Cherokee 4x4
AX15 transmission
4.0L engine out of a 1991 Cherokee (HO?)
Megasquirt 3X with coil on plug ignition and sequential injection
1999 Intake manifold and throttle body
Comp Cams lifters
Comp Cams 68-232-4
Springs that fit and could handle the lift (spec'ed by machine shop since comp cams springs do not work)
Comp Cams timing chain set 3219
The above specs worked out great and we had it all running on the Megasquirt, nice and smooth. That setup also included the older intake and throttle body. What we decided was to go with a bigger cam and change out the intake manifold along with the throttle body to open the top end up a bit. We swapped over the intakes and also went ahead and installed a Comp cams 68-239-4 cam. It all cranks up no problem, but there is a loud clapping noise for a few seconds with cylinder 5, which can be removed if we unplug the coil to it. We are guessing that something is wrong with one of the lifters on that cylinder. But that's not the worst of our problems. As soon as you crank it up, the IATs just start climbing. The IATs get to 200 degrees pretty fast from that point.
Any clue on what could be the cause of the IATs? Is there some goofy timing setup that we need that is different between the less aggressive cam above? Was the cam possibly cut/degreed wrong? What are we missing?
AX15 transmission
Comp Cams lifters
Comp Cams 68-232-4
