pilot bearings?
Posted: January 6th, 2014, 8:10 pm
by vashxj
Hey I cant seem to find a straight answer on this, I cant find it in faqs or searching. So do all 4.0/4.2 cranks have the same pilot bearing hole? I know all the input shafts on the trans side may be different but im swapping my auto to a ax-15 and I have the 4cw long noose crank. If I had to guess I would say they are, just wondering if anyone has run into this
Re: pilot bearings?
Posted: January 6th, 2014, 8:16 pm
by IH 392
Apparently not?, the clutch kit I got for my Wrangler came with two pilot bearings?, I'm not going to stuff one in the crank until I get the thing apart to see what I really need?
Re: pilot bearings?
Posted: January 6th, 2014, 8:22 pm
by vashxj
are both the outer diameters of those bearings the same?
Re: pilot bearings?
Posted: January 7th, 2014, 5:19 am
by Cheromaniac
vashxj wrote:Hey I cant seem to find a straight answer on this
Here's a straight answer for you:
'92-'99 AX15 and NVG3550: OEM pilot bearing 53009180AB for '87-'91 engine or stroker
I'm using the pilot bearing 53009180AB.
Re: pilot bearings?
Posted: January 7th, 2014, 7:18 pm
by vashxj
thanks I just wasnt sure it the back of the crank was the same, haven't taken it apart yet and probably wont until its atleast 40-50 degrees out
Re: pilot bearings?
Posted: January 7th, 2014, 8:55 pm
by IH 392
vashxj wrote:are both the outer diameters of those bearings the same?
NO!
Re: pilot bearings?
Posted: January 7th, 2014, 9:43 pm
by the grey ghost
Prob the smaller one
Re: pilot bearings?
Posted: May 1st, 2025, 10:39 am
by RADARGUS
So, we are having this issue with our stroker. The pilot bearing for the 99 transmission does not fit the 4.2 crank we installed. The pilot bearing for the 4.2 crank has a smaller inside diameter for the older transmission.
Does the 53009180AB pilot bearing fix this issue?
Any suggestion is greatly appreciated.
Re: pilot bearings?
Posted: May 1st, 2025, 1:51 pm
by Cheromaniac
RADARGUS wrote: May 1st, 2025, 10:39 amDoes the 53009180AB pilot bearing fix this issue?
Yes.
