Help diagnosing a noise
Posted: October 13th, 2008, 4:56 pm
New sound.. need help diagnosing it... I'll give you the back story... short
Put on my polished and ported head. It ran perfect.. smooth idle, plenty of power quiet. 300 miles later one of the Comp Cam lifters takes a dump because it was assembled wrong. Bent a push rod and damaged a roller rocker, Pull the head, replace the lifters with some Crower Cam savers and push rods and the damaged rocker. Start her up, break the new lifters in. Runs fine but after like 2 weeks I start hearing a sound again.
When started from cold the sound is not there. The vehicle has to be warmed up and driven for the sound to come around. Once it comes it can be heard at idle, acceleration, basically every where. Its a metallic rattle kind of sound. It seems that if I really push it and get it around 4000 RPM it starts to sound really bad.. almost like pinging (but its not pinging), just starts to sound almost random at higher RPMs. It definitely has a rhythm until it gets to higher RPMs.. I didn't hold it there long enough to really listen to it. It must be driven for it to come about. I pulled the valve cover this evening and let it idle for 30 minutes and the sound never came about, even though I unplugged the electric fan and it got hotter than it usually does.. a bit past 210*. Before I pulled the valve cover the engine was already driven and the sound was there. Pulled it in to the garage, pulled the valve cover and idled it for 30 minutes and the sound never came about. The sound has gotten worse over the course of a few weeks. And it seems to be the loudest just after I come off the accelerator.
At first the sound wasn't that noticeable and sounded like an exhaust leak.. so I had a few small leaks welded up, but the sound was still there. This weekend I replaced the manifold gasket and the donut gasket from the header to the down pipe. Sound was still there and it is getting worse. I also checked the flex plate to torque converter bolts and they were all tight. Didn't see any cracks in the flex plate either. It sounds like it is coming from the back of the engine. And it does seem to be loudest around the bell housing or the passenger side near the rear. I thought that it may just be echoing in the torque converter. Sounds like it might be from inside the block, but can't narrow it down that well. I also checked the preload on the lifters and it is exactly where I set it. 1/2 a turn past 0 lash. I backed it off 1/2 a turn then found 0 lash again and it was right where I set it weeks ago.I thought maybe the cam is fried, but preload hasn't changed one bit.
So I don't know... something with the torque converter? lifter bleeding down? Something else? All fluids are good. Temp stays around 210*, oil pressure is good (20 psi of better)... any ideas?
