Stock timing is used?
Posted: May 18th, 2013, 9:23 pm
by jeep7081
Stock timing is used when putting a comp cam in "231"?
Re: Stock timing is used?
Posted: June 3rd, 2013, 7:22 am
by MoFo
What timing are you asking about, valve timing or ignition timing?
Posted: June 3rd, 2013, 8:25 am
by jeep7081
Ignition
Posted: June 3rd, 2013, 8:34 am
by MoFo
That depends on your engine controls. If you have the 4.0 donor, the computer is in control of ignition timing and you can't change that.
Posted: June 3rd, 2013, 8:39 am
by jeep7081
Just did a cam and performance head swap. Thanks for info.
Posted: June 14th, 2013, 10:19 am
by FlyinRyan
Controlled by the PCM.
Posted: June 14th, 2013, 10:23 am
by jeep7081
dizzy needed to be indexed. Problem solve. She is running. :)
