Valve Spring Question
Posted: May 17th, 2013, 3:51 pm
I am currently rebuilding the engine to go into my Cherokee, not doing a stroker but I understand the experts are on this board. I've run into a bit of a dilemma, using the block and head from a '93 XJ but swapping it into my '99 XJ.
I used a '99 rebuild kit so the block has '99 pistons, cam, oil pump etc.
After sending my head to the machinist I found out that valve springs differ between years, which I didn't know before.
Basically my question is will the '93 springs and '99 stock style cam work together or will I need to pull the springs off the '99 to use?
