Really how much difference?
Posted: February 11th, 2013, 1:22 pm
Well, my question is: How much difference in horsepower and torque between a Comp cams 68-231-4 and an OEM cam?
Engine specs:
KB IC944-040 pistons
'88 258 crank
4.0 rods
stock rockers
Head '93 HO casting 7120 with moderate port and polish (combustion chambers semi-polished, intakes gasket matched and runners blended, exhausts runners smoothed out.)
Head has been milled .015" to flatten out.
Block '89 renix zero clearanced, bored .040" over to clean up.
Ford 24# injectors
This will be going in my '93 XJ with OBD1.
I use it as my DD, (don't have to, but like to) with a lot of freeway miles cruising at 75-80 mph.
I also wheel it on the weekends, live at 4500 feet above sea level and work and play at that elevation or higher.
So really, how much difference is there between the 2 cams?
I've run the numbers through the compression calculator and searched the forum for days, (enough that the wife is irritated with the time spent) and can't come up with real life numbers or even an approximation.
Any help would be appreciated. Thanks
Engine specs:
'88 258 crank
4.0 rods
stock rockers
Ford 24# injectors
