06 4.0 Rebuild Advice (Noob but have read a lot)
Posted: February 5th, 2013, 10:55 am
Hi everyone, looking for some advice here on what to do during a rebuild/motor freshen job. I have a 4.0L with 84k on the clock that I feel is going to give up the ghost soon. On startup I get a horrific clacking noise until it warms it, it’s definitely not a tick, but more of a CLACK CLACK CLACK, which leads me to think bearing failure. I put the Jeep on its side last April but quickly cut the motor after only a few seconds. The noise used to go away at idle, but now it is there ever so softly and is gradually getting worse over time.
I also have an exhaust flutter. Kind of feels like a miss from inside the vehicle but no codes, I can see the RPM drop 50-75 and the timing advance 2-3 degrees for a split second watching my scan tool. Headlights and interior lights also dim a little.
Here is a video of the exhaust noise:
https://www.youtube.com/watch?v=eLB5IvtjCfo
Despite all of this it runs fine, drives fine, and doesn’t feel like there is power loss. I’m just thinking its time to get moving on heading off complete failure when spring gets here.
I’ve looked into stroker, talked to a close friend who had one, and also talked to the owner of a machine shop who is friends with my buddy and did his stroker. My friend has known the owner for a long time and I feel good about pulling the engine and letting him do the work.
I talked to him about the stroker thing, and his advice was to just go .030 over, freshen the block with new bearings, and to just leave it stock minus the bore. His reasoning being you’re sacrificing reliability and such for a stroker, and if I’m looking for power just go with a supercharger kit.
I took a look at this “recipe” and tried to hunt down and price what I’ll need…
My current engine is a 4.0L in an 06 LJ.
Jeep 4.2L 3.895" stroke crank $200 (Won’t have a core to return)
Jeep 4.0L 6.125" rods (My factory rods are this spec, I think)
Keith Black UEM-IC944-030 pistons $565
9.6:1 CR
CompCams 68-231-4 206/214 degree camshaft $136
Ported HO 1.91"/1.50" cylinder head (Valve specs for my current head match this if my research is right)
Mill block deck 0.020"
0.050" quench height
So I’m looking at:
Pistons – 565
Cam – 136
Crank – 200
Lifters – 65
Gaskets - ??? (Haven’t looked into a main gasket set price)
What else am I missing? My 4.0L has that funky OPDA assembly. Do I need to also get new valve springs and rockers? Do I need a different than factory timing set? I’ve been trying to learn as much as I can on my own but I am feeling a little frustrated.
I would like to hear anyones opinions on if I should go for the stroker, or just refresh the motor with a .030 over. I really don’t want to pull my engine and do this all over again for a long time. Having a 4.0 with issues like this at 84k is already frustrating enough…
The way I see it:
Pros –
Buying new pistons anyways
Will be buying new cam/lifters anyways
Will probably do the timing set anyways
Engine will be apart for the rebuild anyways
Extra cost of parts not that much greater than I what was going to buy anyways
DA POWAH
Cons –
Reliability
Drivability
Cost of extra machine work
Cost of supporting mods like injectors, TB Bore, etc
9.6:1 CR
So I’m looking at:
Pistons – 565
Cam – 136
Crank – 200
Lifters – 65
The way I see it:
Pros –
DA POWAH
Cons –
Reliability
Drivability
