				Yeehaw
				Posted: January 18th, 2013, 3:24 am
				by racing89
				1st snow this year.  The comanche was slideways the whole way to work this a.m. Way more fun with a stroker ! Shoveling sucks though!
				Re: Yeehaw
				Posted: January 18th, 2013, 10:17 pm
				by I6FAN
				How much cyl wall do you get with the 4" bore?  I saw a post from HESCO that said the later blocks[year?] were better at surviving a 4" bore due to "oval" shape of cylinder OD with thickest area on thrust side.  What is your experience with that?  I like the idea of the 4-bore, but unsure of cyl thickness/support.
				Re: Yeehaw
				Posted: January 19th, 2013, 2:03 am
				by racing89
				i had only tested the 87- 90 renix ( never found one thick enough), and the 91-95 blocks ( I think, 5 out of 8 had .120 min). Havent tried the newer ones. The 92 block in my dailly driver with .120 min ( # 1 cyl ) has been raced with 11.5 :1 compression, turboed with 9lbs of boost, and had nitrous dumped to it on a few occasions with no problems. Indivisual results may vary
				Re: Yeehaw
				Posted: January 19th, 2013, 10:27 am
				by I6FAN
I hear ya!
Do you have any pics of your intake system?
				Re: Yeehaw
				Posted: January 23rd, 2013, 3:21 am
				by racing89
				i will look. thought i posted one here somewhere.
				Re: Yeehaw
				Posted: January 24th, 2013, 2:40 pm
				by I6FAN
				After I posted that, I thought you may have posted a picture as well (heck, it may have been me that asked for pics back then too
 ).  I actually looked at a few other posts to see if it I could find it; no luck.  If I remember right, it has 3 throttle bodies, mounted side draft, with a common plenum[?]
