Yeehaw
- Vehicle Model: comanche
Yeehaw
1st snow this year. The comanche was slideways the whole way to work this a.m. Way more fun with a stroker ! Shoveling sucks though!
- Stroker Displacement: 4.2
- Vehicle Year: 1987
- Vehicle Model: wrangler
Re: Yeehaw
How much cyl wall do you get with the 4" bore? I saw a post from HESCO that said the later blocks[year?] were better at surviving a 4" bore due to "oval" shape of cylinder OD with thickest area on thrust side. What is your experience with that? I like the idea of the 4-bore, but unsure of cyl thickness/support.
Re: Yeehaw
i had only tested the 87- 90 renix ( never found one thick enough), and the 91-95 blocks ( I think, 5 out of 8 had .120 min). Havent tried the newer ones. The 92 block in my dailly driver with .120 min ( # 1 cyl ) has been raced with 11.5 :1 compression, turboed with 9lbs of boost, and had nitrous dumped to it on a few occasions with no problems. Indivisual results may vary
Re: Yeehaw
I hear ya!Indivisual results may vary
Do you have any pics of your intake system?
Re: Yeehaw
i will look. thought i posted one here somewhere.
Re: Yeehaw
After I posted that, I thought you may have posted a picture as well (heck, it may have been me that asked for pics back then too ). I actually looked at a few other posts to see if it I could find it; no luck. If I remember right, it has 3 throttle bodies, mounted side draft, with a common plenum[?]
Users browsing this forum: No registered users and 25 guests
