68-231-4 cam ok to use?
Posted: December 17th, 2012, 12:02 am
by jeep7081
Not doing a stroker. Doing the head with LS1 valves. I have the 703 injectors. Along with 99+ intake. The exhaust is 2.5" from maifold to tail pipe. Not to mention hypertech III and k&n CAI.
I was wanting to do the head with LS1 valves and a cam. Is the 68-231-4 ok?
97 Cherokee XJ
Re: 68-231-4 cam ok to use?
Posted: December 17th, 2012, 10:47 am
by Cheromaniac
jeep7081 wrote:I was wanting to do the head with LS1 valves and a cam. Is the 68-231-4 ok?
Yeah, that cam will do fine but you'll need to upgrade the valve springs. If you're going to use LS1 valves, the LS1 valve springs should be suitable but check their recommended installed height and the spring pressures before you use them.
Posted: December 17th, 2012, 10:55 am
by jeep7081
Is the cam worth doing? Am I going to notice the power gain?
Posted: December 18th, 2012, 11:20 am
by jeep7081
It says not for fuel injection. Looks like everyone uses it though?
Posted: December 18th, 2012, 12:02 pm
Its their blanket statement for the LSA. It works very well with the stock Jeep fuel injection.
Posted: December 19th, 2012, 4:32 pm
by jeep7081
Ordered and shipped.
Posted: May 15th, 2013, 10:53 am
by jeepers1987
can you use this same cam (68-231-4) on 2001 jeep cherokee 4.0 fuel injection stock?
Posted: May 15th, 2013, 11:05 am
by jeep7081
jeepers1987 wrote:can you use this same cam (68-231-4) on 2001 jeep cherokee 4.0 fuel injection stock?
Yes
Posted: May 15th, 2013, 11:09 am
by jeepers1987
what about 68-201-4 comp cam? with stock valve springs n valves? do i need to have it tune?
Posted: May 15th, 2013, 11:12 am
by jeep7081
jeepers1987 wrote:what about 68-201-4 comp cam? with stock valve springs n valves? do i need to have it tune?
Ask Comp or Ryan (tuner) on here.
Posted: May 15th, 2013, 12:35 pm
by jeepers1987
thanks
