Page 1 of 2
renix stroker troubles
Posted: November 12th, 2012, 4:13 pm
by mousechez
i built a stroker on renix - with adjustable fpr and map - 24lb injectors - idle is good - wot is great - wont level off above 1800 rpm - need help
Re: renix stroker troubles
Posted: November 12th, 2012, 5:16 pm
What do you mean by "won't level off"?
Posted: November 12th, 2012, 5:31 pm
by mousechez
it bucks and backfires
Posted: November 12th, 2012, 8:51 pm
Have you checked your TPS alignment?
Posted: November 13th, 2012, 3:57 am
by cruiser54
When you put the engine in, did you get all the small ground wires reinstalled at a clean and shiny spot at the engine dipstick tube stud?
Posted: November 13th, 2012, 3:46 pm
by mousechez
new tps - and adjustment - grounds all good
Posted: November 13th, 2012, 4:01 pm
by mousechez
tps .8 volts at closed and graduates to 4.8 at wot - map adjusted to around 6.5 volts input
Posted: November 13th, 2012, 6:44 pm
by cruiser54
MAP voltage input is rather high considering stock is about 4.8. Try 5.1 or so.
What fuel pressure are you running with and without the vac line on the fuel pressure regulator?
Posted: November 13th, 2012, 7:26 pm
by mousechez
i dont have a pressure gage - just reset map to 5.4 whithout change - ill pick up a gage tomorrow
Posted: November 14th, 2012, 8:06 am
by Cheromaniac
mousechez wrote:it bucks and backfires
Could be a bad fuel pump, clogged fuel filter, or kinked fuel line.
Posted: November 14th, 2012, 5:19 pm
by mousechez
ok got 43lbs at fuel rail with vacuum and 49 without
Posted: November 14th, 2012, 6:40 pm
by cruiser54
That's quite high. Should be 31 with and 39 without.
Posted: November 14th, 2012, 7:05 pm
Yes, that pressure is too high.
Posted: November 15th, 2012, 3:37 am
by cruiser54
Between the high fuel pressure and high MAP supply voltage, it's gotts be real rich.
Posted: November 15th, 2012, 10:20 am
by mousechez
well i set map and fpr back to stock and condition worsened
