Detonation and piston slap
Posted: August 2nd, 2012, 7:23 pm
by strokedcj8
I have an 82' scrambler with a 4.7 stroker. I built the motor 2 years ago and has never been quite right. I just had to put new pistons and rings in it because of a tick noise. Piston closest to the firewall had shrunk do to some overheating and was slapping the cylinder wall. I put on about 50 miles and now having the same sound. Pulled the oil pan to inspect and looks as though I have detonation in 3 of the cylinders so far. The piston closest to firewall is slapping the cylinder wall again. I need some help, advice, anything! I have dumped so much money into this motor and feel like giving up. Thanks in advance.
Re: Detonation and piston slap
Posted: August 3rd, 2012, 6:14 am
by Cheromaniac
The no.6 cylinder is furthest away from the water pump and will run hotter than the others if there's a blockage in the cooling passages of the block preventing proper circulation of coolant. There could be some ovality in that cylinder since the piston was slapping around inside it.
Posted: August 3rd, 2012, 6:16 am
You just put now pistons and rings in w/o a bore or hone?
Posted: August 3rd, 2012, 8:56 am
by strokedcj8
No, I did have the block honed. I run an aluminum radiator with electric fan. The temp never went over 190. The thought of a blockage makes sense. Thanks I will look into that.
Posted: August 6th, 2012, 6:07 pm
Did you go with over sized pistons, or stock with just a hone?
Posted: August 6th, 2012, 7:17 pm
by strokedcj8
I am running .060 over icon pistons. I did find some info today on my injectors. TOO BIG! 30lb viper injectors. I am going to pick up a set of #24, replace the pistons, rings and bearings. Also change my fan temp switch to be more accurate.
Posted: August 7th, 2012, 5:54 pm
strokedcj8 wrote: TOO BIG! 30lb viper injectors. I am going to pick up a set of #24, replace the pistons, rings and bearings.
Holy crap those are huge! Who's idea was it to use those? I wouldn't doubt it if your oil is diluted with fuel.
