HELP fuel problem
Posted: July 22nd, 2012, 5:39 pm
by EVIL95XJ
Trying to fire the stroker. I have no fuel pressure on the rail. I remove the FPR and get sprayed by fuel?
Re: HELP fuel problem
Posted: July 27th, 2012, 7:58 am
by gradon
Rent a fuel pressure gauge from auto-zone or advance auto. Plug it into rail. Turn ignition on and then go look at the gauge. If you do 2-3 ignition on/offs, you should see it get to 39psi +/- a few. If you see it dropping fast, then you have a bad check valve or leaky injector.
