Gmm213 wrote:This is exactly why I was looking for to get started. Just to do some planning. So the big stokers use a larger 4.2 crank and the minis use a smaller 3.8? And your saying they make roughly the same numbers just on a different curve?
Yes bigger strokers use the 4.2L 258cu crank..has a 3.895" stroker. The mini strokers use a 3.8L 199cu crank with a 3.500" stroke. Stock 4.0 242cu cranks have a 3.410" stroke. The biggest upgrade on the mini strokers is cost is very low, with the crank and appropriate pistons you get a zero deck give or take..so litterally no machine cost to have that done! The bigger strokers will need to be decked for a zero deck. The zero deck gives great efficieny gains..allows for higher compression without the need of higher octane gas because of the tighter quench height!
Honestly I'd love a 4.6L done up right but that would cost me at least 4000 dollars to be realistic! Can be done cheaper but again there is other issues that come with that. Also making sure the trans & transfer & axles can hold that power ect ect..its more than just a motor lol. Also the piston speed & ratio ratio concerned me, more so that I choose to do my 4.2L!
As far as power wise..it truely depends on what you do..cam, ported head ect ect! But essentially if you do it right, yes a basic 4.5-4.6L will make around the same as a 4.2L..just lower in the rpm range..and the bigger motor will cost more & use more fuel...not that thats a concern fro must
Of course you could have a all out 4.6L and it would make more than a all out 4.2L...
By all out, I mean high compression, premium grade gas, ported head, cammed, roller rockers ect ect! Bigger motors always will make more when done correctly..but for your budget, I'd do a badass 4.2L...it'll be efficient as all hell..who knows how much mileage it may gain over a stock 4.0..but it'll be more efficient
and if taken care of correctly it will last, if not out last a stock 4.0. Its 100% the same except your uipgrading! Piston speed & rod ratio change almost nothing, a forged dual roller timing chain, ect ect..you can make it outlast a stock 4.0!
Porting/cleaning up the head goes a long way! Polish the combustion chambers & exhaust runners will also help alot..polished chambers prevent detenation, and polished exhaust runners keep exhaust moving fast and smooth out of the head! Honestly the head is where you will gain alot I think! The 4.2Ls are very simple to do, crank and pistons & otherwise a stock bottomn end rebuild!
I spent alot of time doing my head with stones & paper rolls. This took more time than using carbide bits but I didn't screw up at all, and I got it exactly how I wanted. Using carbide bits can be dangerous as they take away alot of material very fast..I took the slow and steady route! My chambers & exhaust runners are near glass smooth! My intake manifold..or what I could reach is also glass smooth. the intake runners were cleaned up then polished with 80 grit rolls to help with fuel atomization!
I will be running 1.55" ls6 sodium filled exhaust valves, and 2.00" ls1 intake valves. The intakes will be turned down to a 1.92-1.95"..haven't decided yet. My cumbustion chambers are 61cc currently with stock valves. With the new valves, they have tuliped undersides, I will gain a cc or 2! This may not seem like much but it helps get the quench height as tight as possible, which allows for more compression without detenation! Compression and flow build power in a N/A motor
Focus on the head, try to run tuliped valves & polish up the chambers. Buy a good 7120 cast head and start working on it..then buy your bottom end and build it! Get your head build correctly! Do it badass, 100% like you want..and go slow. Then build up a bottom end and slap them together! Exactly what I did. Alot goes into porting..but its really not bad when you get into it!
My jeep is an 88. It makes 170hp & 220ftlbs in stock form. Its now with 100% bolt ons around 190hp and maybe 235ftlbs. The 4.2L mini stroker with the same bolt ons should be making 250hp minimum and around 300ftlbs..I'm hoping mine will be making slightly more but honestly thats a 80hp jump..you are gaurnteed to notice that lol.
