Rear main seal sealant?
Posted: June 8th, 2012, 8:14 am
				FSM calls for loctite 518. None of the parts stores around me carry loctite brand. What is best to use?
			Jeep - AMC 4.0L and 4.2L Stroker Enthusiasts
https://www.jeepstrokers.com/forum/
FSM calls for a anaerobic sealant, loctite 518 which i found in permatex brand part number 518135-90 wrote:On which bit?
I've always used the later (1996-up) one-piece moulded gasket (dry) and dropped the new RMS in clean engine oil before I started tearing things down - let it soak until you install it.
FSM says to put a touch of RTV on the ends of the seal, but I've not bothered - that's why I soak it.
Haven't had any trouble, just don't install the seal backwards.
I know - where does it say to use it? That's the part I don't recall (often, the two-piece moulded rear mains want it between the ends of the seal halves. The old "rope" seals just get trimmed and run.)EVIL95XJ wrote:FSM calls for a anaerobic sealant, loctite 518 which i found in permatex brand part number 518135-90 wrote:On which bit?
perfectSilverXJ wrote:This may help: http://www.go.jeep-xj.info/HowtoRearMain.htm
