Big Valve Stroker Motor
Posted: July 21st, 2008, 9:36 pm
Hey all. I am new to the site. I know people have posted threads on the build up of the motors. I am trying to get a little more detailed information, and more pictures of the processes.
I have been posting this build on other sites for quite some time. A member thought I should post it over here. I will continue to post to get this site up to speed on the progress.
The motor is going into a 94' Grand Cherokee. The transmission has been gone through my Mysak's, and I got a new drop-in select-trac unit from George Kreppian at Transfer Cases Unlimited. (I was tired of replacing the viscous coupling.)
A couple of Fridays ago I went to Fayette, Ia to pick up a 1988 4.2L Jeep motor. I still have the old block I took out from last year's modified old 4.0. I will also be using the larger valve spring retainers on the stroker motor.
I will be updating the HO head I have to accept new, larger valves. The intake will be going from 1.91" valve to a 2.02" stainless, swirl polished LS1 valve.
The exhaust will be going from a 1.50" to a 1.60" stainless, swirl polished LS1 valve.
We will be milling the stud bosses down .400" and drilling and tapping them to accept 3/8" screw-in studs. They will also get Comp Cams push rod guides, custom length Comp Cam moly push rods and Comp Cams 1.6 aluminum roller rockers.
I already have the intake manifold modified currently running on the 4.0L motor I built last summer. Along with the Doug Thorley headers and 2.5" Borla exhaust. Here are some shots of the standard manifold, the new manifold with waaaay better runners and how they were modified.
I also have the 55mm throttle body bored to 62mm. That is also on the motor. In order to get the manifold to fit, I had to grind off the power steering boss on the manifold. I then made a bracket that bolts to the back of the power steering mount. This way I don't
have to change any of the pulleys around, and still use the stock set up.
The new 2000 manifold has the A/C compressor on the opposite side of the motor. I didn't want to have to change everthing around. So I made a bracket to keep it as is.
Here are some pictures of the old stock exhaust manifold, and the new Doug Thorley header.
These are some shots of the timing gear that I modified to accept the SBC offset keyway to either advance/retard the cam timing from 0 degrees to 8 degrees.
I dropped off the head and block to be hot tanked and magnafluxed to make sure there are no cracks in them. I am waiting on the new valves so Sperry Engines can do the initial cut on the valve seats to open them up. Then I can start on the port work. Once the port work is done, they can go back to the shop to put the 3 angle valve job on them.
He can also measure up the block to make sure the 0.030" over pistons will clean up the cylinders.
The crank has to have 10mm milled off the end. (I think Dino has mentioned this previously, as well as some others.) The crank cleaned up at 0.010/0.010".
If anyone sees any errors in thinking, please let me know.
Here is a picture of the new 2.02" stainless intake valve compared to the old 1.94".
Here is the new stainless 1.60" exhaust valve compared to the new 1.60"
All of them together..
Here is the 4.2L rod before polishing the beam. Once they are all complete. I will balance them and install new ARP rod bolts. Then they will be sent off to be shot peened.
Here is the beam after being stressed relieved and polished.
I went to the machine shop this morning as Scott had one cylinder done with the rough-in for the 2.02/1.60 valves, and bronze insterts installed in the guides. I wanted to get some before and after shots.
The finished installed height is going to be 1.630". The new springs I have ordered are Australian fine-wire performance springs that have 115# @ 1.625". Those should be about 110# @ 1.630". I am getting the valves, springs, retainers and keepers from http://www.engnbldr.com. Ted Stanford is AWESOME to work with.
Here are the shots of the roughed in cylinder compared to the standard cylinder. I will be picking the head up on Friday after work to begin the port work. Once I get the port work complete in one cylinder, I will be heading over to the Super Flow Flow Bench to see where we are at with the numbers.
I also have to open up the combustion chamber from 57cc's to 62cc's. This will bring down the compression to 9.2:1, and allow me to run the stock 0.045" quench and unshroud the new, bigger valves.
Before any work:
After the rough-in:
Side-by-side comparison:
Madness is the gift that has been given to me....
Before any work:
After the rough-in:
