				anyone make a carburated stroker?
				Posted: March 2nd, 2012, 5:33 am
				by samm895
				Building my yj now. I want it to be as simple as possible. The only things I wanna keep are lights, turn signals, and maybe a radio. Has anyone else dumped the fuel injection system and gone to a carb? What's the easiest way to get the thing sparking once I do?
 I am building a calm 4.6 or maybe 4.7 BTW.
				Re: anyone make a carburated stroker?
				Posted: March 2nd, 2012, 6:47 am
				by johnhalabama
				I'm building a carburated 4.6 stroker for a 1936 Dodge of all things.  But, I'm running a clifford intake and split headers & I've talked to Summit Racing and they have a HEI distributor that they say will work with a 96 4.0 but still looking into that.  270 Isky cam, KB pistons.  It will be interesting to keep up with your thread.
				Posted: March 2nd, 2012, 10:42 am
				by Missourian
				I have seen a HESCO 4.7L STROKER that was all mechanical and sported an aluminum head! I should have bought that engine.
				Posted: March 2nd, 2012, 7:34 pm
				by IH 392
				YEP!, the class that my dad races in requires a straight six and a 1BBL carburetor!, for ignition just run the AMC/Jeep/Ford "DURA SPARK" distributor with a GM HEI 4 pin modual, or if you can find one get a coil in cap HEI out of a Chivy six and put the AMC gear on it (the cams turn the other direction so the gears are pitched the other way) and you'll be good to go!
				Posted: March 3rd, 2012, 2:34 pm
				by samm895
				Thanks a lot. This will make life much easier for me.
				Posted: March 10th, 2012, 7:56 am
				by stroked'73
				I have a quadrajet on mine - goes good. Stock '73 AMC 258 dizzy (delco) with pertronix. An hei would be simpler tho like IH 392 said. The dizzy gear is cheap too IIRC.
				Posted: March 10th, 2012, 8:17 am
				by gonridnu
				I built a hipo slant six for a friend of mine and we used a clifford intake with a Holley 450 cfm 4 bbl.  A 282" Jeep stroker engine at 5500 RPM with 83% VE works out to right around 450 CFM.
				Posted: June 13th, 2012, 6:54 am
				by Zorm
				So what about modifying a 4.0 intake to accept a 4 bbl. I am talking like making the inital bore larger and mounting the carb up a little higher, I atually have some 1/2 thick ALm thats about 6" wide by 2.5" long I can cut up. Too bad I already sold my other 258 intake and HEI dizzy.  What size carb would I be looking for if I have a 4.6 and stock cam.
				Posted: June 17th, 2012, 9:12 am
				by superj
				one of the guys on jeep forum has his set up that way.
i have a 450 holley on mine with an offenhauser intake and it works great
