dieing 4.0 problem
Posted: February 10th, 2012, 1:10 am
well i have a 92ish jeep wrangler with a dieing 4.0 it has a mild case of lifter tick, some rod knock and piston slap so it needs a major overhaul instead of just rebuilding it i am going to make it bigger and better via a 4.7 long rod stroker since i will be reworking the suspension next month now is the time for the build
so here is the plan
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
IC944-060 pistons
9.36:1 CR according to the calculator
a stock 7021 HO cylinder head that is gasket matched
Mill block deck 0.020"
0.050" quench height
Ford 24lb/hr injectors with adjustable FPR
99 4.0 intake
stock exhaust manifold with a 2.5" exhaust all the way back
and bore the taper out of the throttle body and gasket match the intake
here is what it is going in
right now it has d44's f&r but is getting a ford 9" rear spooled with 5.13's and the welded front and matching gears
so is there any thing i need to do or not do also what should i do about the computer
so here is the plan
IC944-060 pistons
99 4.0 intake
