Page 1 of 2
new to the forum
Posted: January 27th, 2012, 2:33 pm
by boomerjeep
as the title says im new to the forum and im in need of some help. i am getting ready to pull my engine and have decided to go ahead with my idea of building a stroker, my issue is that im looking for a parts list of everything i will need. im sorry if there is already one on here, i havent found it yet. any help you guys can give me would be greatly appreciated.
Re: new to the forum
Posted: January 27th, 2012, 5:22 pm
by Muad'Dib
Best to read the FAQ's and the posts in the "Projects" section to get started.
Posted: January 28th, 2012, 5:01 am
by Cheromaniac
boomerjeep wrote:as the title says im new to the forum and im in need of some help. i am getting ready to pull my engine and have decided to go ahead with my idea of building a stroker, my issue is that im looking for a parts list of everything i will need. im sorry if there is already one on here, i havent found it yet. any help you guys can give me would be greatly appreciated.
What do you have now and how much do you have to spend on your stroker project? What type of use will the stroker be subjected to?
If you can answer those questions we can advise you on which parts to get and where to get them from.
Posted: January 28th, 2012, 8:40 am
by Retlaw01XJ
This short list sums up 99.5% of what you'll need:
Crankshaft
Pistons
Bigger fuel injectors
Engine kit from a supplier like Falcon Global or Northern auto parts
There would be additional options such as a performance cam, valves/springs, roller timing chains, ARP rod bolts, etc.
Posted: January 28th, 2012, 10:03 am
by boomerjeep
i have a stock 4.0 jeep right now. ive got roughly 2500 to spend. i called a machine shop here in el paso yesterday and they quoted me 460 to bore the block, 3 degree valve job, decking if needed, balancing crank, shot peening rods and pressing the wrist pins and cam bearings. my jeep is mainly used for rock crawling and trail runs.
Posted: January 29th, 2012, 2:20 am
by Cheromaniac
boomerjeep wrote:i have a stock 4.0 jeep right now. ive got roughly 2500 to spend. i called a machine shop here in el paso yesterday and they quoted me 460 to bore the block, 3 degree valve job, decking if needed, balancing crank, shot peening rods and pressing the wrist pins and cam bearings. my jeep is mainly used for rock crawling and trail runs.
Then this stroker recipe should be within your budget if you're doing the engine teardown/rebuild yourself:
4.6L low-buck stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
Keith Black IC944-030 pistons
9.6:1 CR
Mill block deck 0.020"
0.050" quench height
Ford 24lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 24lb/hr injectors with stock 49psi FPR for '96 and later engines
What year is your Jeep?
Start looking for a 258 crankshaft in ebay to get the ball rolling.
Posted: January 29th, 2012, 5:23 pm
by boomerjeep
i have an 02 sahara. i really appreciate your help
Posted: January 30th, 2012, 10:16 am
by Cheromaniac
Summit Racing is the best place to source most of the parts.
I'll put up a parts list in a separate post so others can use it as a reference.
Posted: January 30th, 2012, 3:01 pm
by boomerjeep
that would be a huge help! thank you very much.
Posted: January 31st, 2012, 2:46 pm
by Cheromaniac
boomerjeep wrote:that would be a huge help! thank you very much.
Here ya go:
http://www.jeepstrokers.com/forum/viewt ... =15&t=3030
Posted: February 1st, 2012, 12:47 am
by boomerjeep
Posted: February 1st, 2012, 3:39 am
by Cheromaniac
Yup. Good choice.
Posted: February 1st, 2012, 4:32 am
Cheromaniac wrote:Yup. Good choice.
Wait.. what? The springs retainers and locks won't work.
Posted: February 1st, 2012, 4:40 am
by boomerjeep
so i would be better off just getting the cam and lifters?
Posted: February 1st, 2012, 6:33 am
yes
