Noob ECM/ECU swap question
Posted: December 28th, 2011, 4:01 pm
by Kapper
I have built a 4.6L stroker that I am installing into my 94 wrangler that came stock with a 2.5L. I am at the stage of wiring and I believe the ECU/ECM that a friend gave me from a Grand Cherokee will not work becuase of the auto theft security system. Because of this, I am now looking for a 94 YJ 4.0 M/T ECU/ECM but cannot find any at a reasonable price in my area. However, I have found some 4.0 94 and 95 Cherokee (not Grand) M/T ECR/ECM's for fair prices. My only problem is I am not sure that these ECU/ECM's will work for my 4.6L in my YJ. I am using the wiring harness from the YJ 2.5L but I have modified it to add the extra injectors and I used 4.0L TPS and IAC etc.
Does anyone know if the 95 and 94 4.0 M/T Cherokee (not Grand) ECU/ECM's will work?
OR
Does anyone know of a fix or work around for the security on the 95 Grand Cherokee ECM/ECU if that ECM/ECU will even work?
Thanks for the help.
Re: Noob ECM/ECU swap question
Posted: January 13th, 2012, 5:53 am
by carlitos
The 94 & 95 Cherokee ecu should work for your 4.6 just mite have to use a map sensor voltage adjuster to fine tune the engine
Posted: January 13th, 2012, 8:49 am
by racing89
Will work. Even had a guy use the original 2.5l harness and added 2x injecter wires to go along with his 94 cherokee 4.0l ecm
Posted: January 13th, 2012, 6:53 pm
by amcinstaller
if it does in fact have the security, youll likely only run into issues if you use the power locks. even then, theres a violet wire with a yellow stripe that would be in the drivers kick panel of the grand cherokee that you can pulse with a negative to shut it off. but honestly unless you end up hitting the lock button (which wont likely exist in a wrangler) before you close the last door, that wont be an issue. also, there is no key/transponder based shutdown in those jeeps.
Posted: November 29th, 2013, 7:01 pm
by dirt5track
Not sure if it's the same but on my '92 xj Cherokee the theft system would come on automatically if the battery was unhooked. When I moved my stoker to my yj I tried to use the ECM out of the xj and could not find the correct wire to ground and deactivate it. The xj had already gone to scrap. I had to find a wrangler ECM and now need another one due to a short. Very hard to find. Hope this helps. If you can find the pin location on the ECM of the Cherokee you can make a wire that come off of that pin to ground it out.
