oil filter adapter and strokers
Posted: October 14th, 2011, 5:54 pm
by Jor2010dan
So I took out my oil filter adapter before I sent my engine to the machine shop to get stroked:D
Because of that, I will have to run a smaller filter.
Has anyone done this? Is it stupid or should it work?
Re: oil filter adapter and strokers
Posted: October 15th, 2011, 9:10 am
by Shark
What makes you say youll have to run a smaller filter? will you be changing the adapter?
Posted: October 15th, 2011, 10:49 am
by Jor2010dan
eliminating it all together. Oil filter directly on the block. (eliminates 3 leak points)
Posted: October 16th, 2011, 7:32 am
by wildspear
You should be just fine. Leave that adapter off and get a K&N filter.
Posted: October 16th, 2011, 12:36 pm
by doc65
not to be picky, but doesn't it just eliminate 2 leak points, going from 3 by my count to 1? Unless you count the internal oring aroung the "bolt" in the center of the adapter housing that is... Or am I missing something?
Posted: October 17th, 2011, 11:53 am
by Jor2010dan
Thank you for that.
Posted: November 9th, 2011, 4:26 pm
by cruiser54
There's very little clearance for engine movement in an XJ when you remove the oil filter adapter and install the small filter directly on the block. Quite easy to have the oil filter collide with the motor mount causing catastrophic oil loss when the filter is punctured..
Posted: November 9th, 2011, 5:46 pm
x2. AFAIK all XJs had the 90* adapter. ZJs as well. Not enough clearance for a straight attachment. But the 90* isn't all that bad as it allows you to run a larger filter.
Posted: November 10th, 2011, 4:32 am
by Cheromaniac
I have my oil filter adapter bolted on like this:
Posted: November 12th, 2011, 3:57 am
by cruiser54
I truly believe that if the factory could have saved the money they had to spend on each and every oil filter adapter installed on a 4.0 in an XJ or MJ, they would have not gone to the trouble of having one. There are people on some of the other forums who went to great lengths to eliminate the OFA only to find that if their motor mounts were the least bit worn the filter would get punctured or dented in off-road conditions.
