Status update: over 20,000 miles on the stroked engine, still running strong. No issues starting even in summer hottest (110°F) or winter's coldest (-20°F). I ran high octane to start but have been using standard octane (87) for nearly two years now.
My only issue to date is with my using a High Volume Oil Pump, the pressure gauge now shows 80 psi. When the motor was first installed, the pressure was 60 psi. This is the oil pressure at highway speeds of 2400-2500 RPM. The pressure does drop off with slower RPM's to idle around 600 RPM. And then the pressure never drops below ~30 psi. So, I don't know if this is cause for concern perhaps the pump is flowing better after break in, I hope it is not cause for concern due to a blockage. The coolant temperature has remain consistent throughout this time, it stays about ~190°F.
Maybe y'all have some input or similar experience?
Anyway, I am very happy with my investment. My Jeep is very reliable and much more powerful than stock. Some of the articles I have read in JP magazine and others about Stroking the 4.0L have me wondering where these guys came up with the idea it was not worth the money, time or trouble to stroke a Jeep to 4.6L. Perhaps the motors they were writing about were too aggressive... I don't know.
The Modified Poor Man's Stroker is what I chose for my build with it going into a 2000 Jeep Wrangler w/computer control everything engine. Like I have said; it is very reliable 4.6L STROKER!
My first 4.6L STROKER of three planned
- Missourian
Re: My first 4.6L STROKER of three planned
Congrats on the mileage. Its always good to hear a positive report after the initial build.
I wouldn't think the pressure would increase as things break in. 80psi is quite high. Perhaps the bypass valve in the pump is having an issue. But, first I would verify with a known good mechanical gauge what the true pressure is. Could be a bad stock sending unit.Missourian wrote:My only issue to date is with my using a High Volume Oil Pump, the pressure gauge now shows 80 psi. When the motor was first installed, the pressure was 60 psi. This is the oil pressure at highway speeds of 2400-2500 RPM. The pressure does drop off with slower RPM's to idle around 600 RPM. And then the pressure never drops below ~30 psi. So, I don't know if this is cause for concern perhaps the pump is flowing better after break in, I hope it is not cause for concern due to a blockage. The coolant temperature has remain consistent throughout this time, it stays about ~190°F.
JP Magazine needs to be taken with a cup of salt. I stopped reading it a long ago due to inaccuracies.Some of the articles I have read in JP magazine and others about Stroking the 4.0L have me wondering where these guys came up with the idea it was not worth the money, time or trouble to stroke a Jeep to 4.6L. Perhaps the motors they were writing about were too aggressive... I don't know.
- Missourian
SilverXJ wrote:Congrats on the mileage. Its always good to hear a positive report after the initial build.
I may swap the sending unit out from my other 2000 Jeep Wrangler w/4.0L, just to see if it changes. I don't have a 120-150 PSIg direct read gauge to swap in to check it out. I may have to call the engine builder and get his thoughts on this oil pump. Thanks for the advice.SilverXJ wrote: I wouldn't think the pressure would increase as things break in. 80psi is quite high. Perhaps the bypass valve in the pump is having an issue. But, first I would verify with a known good mechanical gauge what the true pressure is. Could be a bad stock sending unit.
I am coming to that conclusions as well but I am locked in for another two years subscription. It could be worse, I could have paid retail for all those magazines.SilverXJ wrote:JP Magazine needs to be taken with a cup of salt. I stopped reading it a long ago due to inaccuracies.
