OK I'm at the point of having the handfull of parts at the end ( or close to it )
I would like to pick your collective brains here!
Most of the unknown parts are gaskets, or in this case an "O" ring.
Three O rings in the gasket kit; lg., med., and small. Where does the small one go?
Large
Med.
and small.
Part that bolts into block that holds oil filter (dim)
More to come! There are about 6 gaskets that I can't identify.
Thanks!
J.B.
Where does this go pt. 1
- Stroker Displacement: $.6 mistake?
- Vehicle Year: 1986
- Vehicle Model: CJ7
- Muad'Dib
Re: Where does this go pt. 1
Look at the second picture... Next to the finger nail that is pointing to the outer medium size o-ring that has the smaller one on it. See where the bolt is there?? Look at the pic again closer and you can see the o-ring on the bolt right next to your nail.
Hope that helps.
Hope that helps.
Yep, that was it. It was flattened and hard as my grannies tonails.
Tnx.
More to come! I think I will open them all under the same thread, just one at a time. Thanks again!
J.B.
Tnx.
J.B.
Users browsing this forum: Ahrefs [Bot] and 22 guests
