Newbie build in progress need advice on CR and Quench
Posted: June 15th, 2011, 1:23 pm
Hi Everyone, I am new to the stroker builds, but have been doing a great deal of reading and now I'm in the progress of building a 4.6 stroker. I have some questions regarding CR and Quench height that I need advice on. First here is what I am building.
Renix 4.0L
4.2 Crank
4.2 Rods
Standard .030 13cc dish Cast Pistons
Comp Cams 68-231-4
94 HO head Ported and Polished 58cc C.C.
Using the 4.0 stock Deck Clearance .0215 in the calculator I get SCR 10.07:1, DCR 8.8:1, and Quench is 0.0655.
With everything I have read, the CR values seem high for a daily driver/weekender. I am wondering if the notorious knock and high octane requirement is based on the SCR or DCR value.
Quench also seems a bit high but this is using the stock deck clearance rather than measured. The deck height is at stock and all the parts are off being balanced so I can’t measure the actual. I would like to be ready to decide if I need to deck the block by the time they return to the shop from the balancer.
OK so here are my questions:
Does anyone know the deck clearance with stock 4.0 deck height using 4.2 crank and rods with standard 13cc pistons?
Is SCR of 10.07 and DCR 8.8 likely to require high octane fuel in order to avoid the knock?
Is the Quench of 0.0655 acceptable or will I loose all the power I have been shooting for by not decking the block?
Sorry if these are familiar questions. I can find some posts that come close to answering these but they all seem to be for strokers using 4.0 rods and custom dish pistons or some other variation of recipe. As a newbie I just don’t want to make costly mistakes because I failed to ask stupid questions
Thanks for any help. God bless!
Renix 4.0L
4.2 Crank
4.2 Rods
Comp Cams 68-231-4
