Dilemma
Posted: April 30th, 2011, 12:01 pm
				I started off with a plan. Build a 4.5 stroker out of my 4.0 in my Jeep with a blown head gasket. It has 179K on the block. I wanted to do a 4.5 stroker because I do not have a ton to spend, but I know what building a stroker costs. The Jeep is a daily driver so, my logic was to build a motor with a little extra kick of power (hence the 4.5, not larger) Well......I talked to a friend yesterday who is a mechanic. He's ASE, 20 yrs exp ect. I trust him. I asked what he thought and he unraveled my tight knit plan pretty quick. He suggested that I have the block stripped down bare and have it tested by a machine shop for wear in the cylinder walls since I have 179K on my block and he informed me that if I use standard bore pistons and new rings, there's a good probability that my engine won't last near as long as one built with freshly bored cylinder walls. My main concern (besides money) is doing this stroker the right way. I do not want to take the easy way out and pay for it 10K or 20K miles down the road. However, I am a little nervous about jumping right into a 4.6 or 4.7 stroker and having to make adjustments in my plan and spend alot of extra money on parts to compensate for a hotrod motor. I posted this here, because this site is a wealth of stroker knowledge and I just want to make sure that my mechanic friend is sending me on the right track. Jeeps are not his specialty, so I want to be sure that there isn't something I'm missing that could keep me on track in building a 4.5 budget stroker.
