SCAT Crankshaft Snout Grooves
Posted: January 15th, 2011, 2:25 pm
by petergunz1
I just received a new 4.2L Scat crankshaft and noticed the groves that are suppose to be in the snout that insert through the timing set and the harmonic balancer are not there. I am not sure what these are called, but are these something that I need to buy separately and have them pressed in?
Re: SCAT Crankshaft Snout Grooves
Posted: January 15th, 2011, 2:40 pm
by petergunz1
Nevermind, I answered my own question. They are the crankshaft keys. Still don't know where to get them or why they didn't come with the crank.
Posted: January 15th, 2011, 5:22 pm
by 92tank
use side cutters to take the ones out of your old crank and clean them with a file you put grooves in them
Posted: January 15th, 2011, 6:18 pm
by IH 392
Use a punch tap from the end on top and roll them out or a chisel and go at them from the bottom side, punch, chisel or dykes you'll probably need to dress the "woodruff" keys with a file, tap them back into your new crank.
Posted: January 15th, 2011, 8:44 pm
I've never seen a crank come with them. The one for the harmonic balancer can be gotten from lowes or home depot or ace. I don't know about the one for the cam gear though. I know it can be had through the dealer, but it might not be available ins a hardware store.
Posted: January 20th, 2011, 3:20 am
by petergunz1
As it turns out, these little guys are hard to find. I went to the dealer today since I needed to pick up some other stuff and they can get the key for the harmonic balancer, but the diagram showing the key for the timing set was listed for a 1993 Wrangler. They were only $2 so I ordered them all. The rep from Scat stated that any 3/16 x 3/4 key will work and that they should be available at NAPA.
