The Best Engine - 4.2 to 4.0 Swap
Posted: January 12th, 2011, 2:53 pm
by AUGUST
I am moving forward with a replacement engine for my 86 CJ. Because I will be building a stroker to replace my 4.2 I would like to use the best engine possible. I believe I am hearing the 1994 Wrangler 4.0 HO is the one to go with. As I look I am running across quite a few cherokee's and was wanting to know what year/years would be comparable? I am looking to pick the folowing items:
The head, intake (w/ throttle body and injectors/fuel rail) and exhaust manifolds, computer (PCM), complete engine bay wiring harness in one piece (cut off the trunks that lead throught the fire wall), fuse box (PDC) & its' mounting bracket, throttle cable, MAF sensor, distributor and ignition coil, waterneck, all the sensors (O2, water, Etc).
Thanks for the help!
Re: The Best Engine - 4.2 to 4.0 Swap
Posted: January 12th, 2011, 7:35 pm
by IH 392
If I were going to do a complete conversion I'd look for an "OBD II" '97 and later, they seem to be the most user friendly, and yes get it ALL.
Posted: January 12th, 2011, 7:39 pm
by YJason
Have you read through the FAQ section? it tells what the pro's and con's of each yr of heads, blocks, cranks, etc.. As far as the wiring goes 95 and older OBD1 will be slighlty easier with a couple less wires to hookup than a 96+ OBD2. As far as the rest of the bolt ons, IMO any year 4.0 will be good. You can get a 99+ intake which is suppose to be better. Just watch using a XJ, the cooling fan is setup to run offset to the passenger side to make room for the electric fan. You'll have to do a little research on what it takes to put the fan back on center if you plan to use a mech fan. Probably just a new water pump (wrangler style) and maybe a idler pulley.
Here is what I went thru, when I swapped from a 4cyl to a 96' XJ 4.o and AW4 automatic.
http://bluegrass4x4.org/forum/viewtopic ... hilit=swap
and here is a long thread with a lot of BS from my friends of my stroker build:
http://bluegrass4x4.org/forum/viewtopic ... r&start=10
