Which Injectors, Throttle body?
Posted: December 30th, 2010, 11:22 am
My stroker is officially worn out. Had 0.018" piston to sidewall clearance at the bottom of the cylinders (with pistons pushed to one side, 0.009" all around). Since I have it in my car and don't really need all the low end torque, I'm rebuilding it as a 0.060" over 4.0L (I'm guessing... don't think it will pass at 0.040" though, but depends on the pistons). So I'm using the 4.0L crank and rods. I'll build another stroker with carb for my Jeep truck this summer though.
My problem now is what injectors to use, and what throttle body. I have a bored out Renix TB that I had planned on using. The large TB shouldn't hurt anything, might make throttle response better and could lean out at WOT, but this cruiser should rarely see WOT. Opinions? Is using the bigger TB a mistake? I'm putting it on a 1999 intake, already made an adapter for the Renix TB.
Will the 24# injectors (Ford Motorsport) I was running with the stroker be too big though -- should I got back to the original 19# injectors? I also have a set of injectors from 96-99 model, which should be 23#. According to my Chilton's Jeep manual (84-96) the fuel pressure at the rail was the same from 87-96 for the 4.0L. The rail used no return line though (bought entire head with manifold and injectors from a motor with rod through the block). I thought those used 49 psi at the rail. If so, the 23# injector will flow 20.5# at 39 psi, just a little more than the 19# injectors. Or are the injectors all rated at the 43.5 psi standard most aftermarket injectors use?
