stroker in an 04
Posted: December 4th, 2010, 1:20 am
hey guys, ive read tons and tons of threads and forums on strokers, but i still cant find the answer im looking for. I have an 04 wrangler with a 4.0 that threw a rod, so its not rebuildable, so Im looking for another engine to put in there and figured i might as well stroke it. MY questions is, can i use a long block out of say an older XJ or Yj or something like that? Ive found used XJ engines for cheap, but for anything 02 and newer its always super pricey. If I use the long from that can i use my intake and everything from my stock 2004 4.0? heres what im going for right now.
Jeep 4.2L 3.895" stroke crank
Jeep 4.2L 5.875" rods
Silvolite UEM-2229 +0.030" bore pistons
Increase piston dish volume to 30cc
8.75:1 CR
Mill block deck 0.035"
0.058" quench height
Ford 24lb/hr injectors with stock 39psi FPR for '87-'95 engines, stock injectors with stock 49psi FPR for '96 and later engines
240hp @ 4700rpm, 315lbft @ 3000rpm
8.75:1 CR
